17 years agoError during building the Toolchain
Hi all, I'm trying to build the Toolchain for Nios2Linux, so i followed this (http://www.nioswiki.com/installnios2linux) guide. at the make gcc stept i get the following error: ...
17 years agoI'm in the same boat here... it compiled for a while then got to a point where it error'd out. Now whenever I try to re-run the compilation the first line complains about "Board not defined..."
I'm compiling under Ubuntu linux running Kubuntu, and am following the InstallNios2Linux tutorial. So far I've been able to fumble around and get this working thus far. Below is my terminal output should someone find it helpful. I'm sure I'm missing something simple here. Is it as simple as defining the target board? I'm using the DE2-70, not sure if there's some alias that it's expecting for it... <div class='codetop'>CODE</div><div class='codemain' style='height:200px;white-space:pre;overflow:auto'>todd@Zorak:~/Desktop/nios2linux_src/nios2-linux/toolchain-build$ make gcc elf2flt gdb-host /home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/u-boot.mk:11: Board not defined! Using EP1S10 as default. PATH=/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/nios2/bin:/home/todd/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/nios2/bin make -C /home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build all-gcc make[1]: Entering directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build' make[2]: Entering directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/libiberty' make[3]: Entering directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/libiberty/testsuite' make[3]: Nothing to be done for `all'. make[3]: Leaving directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/libiberty/testsuite' make[2]: Leaving directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/libiberty' make[2]: Entering directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/intl' make[2]: Nothing to be done for `all'. make[2]: Leaving directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/intl' make[2]: Entering directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/gcc' gcc -g -O2 -DIN_GCC -DCROSS_COMPILE -W -Wall -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes -pedantic -Wno-long-long -DHAVE_CONFIG_H -I. -I. -I/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/../gcc3/gcc -I/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/../gcc3/gcc/. -I/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/../gcc3/gcc/../include -DTARGET_MACHINE=\"nios2-linux-uclibc\" -c /home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/../gcc3/gcc/collect2.c -o collect2.o In function ‘open’, inlined from ‘collect_execute’ at /home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/../gcc3/gcc/collect2.c:1537: /usr/include/bits/fcntl2.h:51: error: call to ‘__open_missing_mode’ declared with attribute error: open with O_CREAT in second argument needs 3 arguments make[2]: *** [collect2.o] Error 1 make[2]: Leaving directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/gcc' make[1]: *** [all-gcc] Error 2 make[1]: Leaving directory `/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build' make: *** [/home/todd/Desktop/nios2linux_src/nios2-linux/toolchain-build/build/gcc-bootstrap-build/.compiled] Error 2 todd@Zorak:~/Desktop/nios2linux_src/nios2-linux/toolchain-build$ </div>
