15 years agoError: Downloading elf file. Problems with SDRAM?
Hi! I've got some trouble with the NIOS II IDE. I've build a SOPC Builder System which is working fine on a DBC3C40 development board which includes a Cyclone III FPGA. Now I got the new vers...
15 years agoThere is a memory test software example in the Nios IDE. Compile it, run it from the on chip memory and have it test the SDRAM. It should help you figure out if something is wrong.
