Broddo
2 years agoError creating a bsp with niosv-bsp
I'm trying to migrate from nios ii to niosv. I've generated a license for a niosv/g, imorted it into Quartus and I've successfully swapped the nios ii for the niosv in Platform Designer. The assembl...
tehjingy_Altera
2 years agoHi
Sorry for the late response.
I see that you have downloaded the NiosV/g processor and using the Quartus 23.1.
There are a few release after the 23.1.
In 23.1 it only supports the NiosV/m that could be the reason why you are facing the errors that you are looking at.
It is weird that the upgrade tool did not flag an error on this.
However would you mind installing the latest Quartus 24.1 and try it out again?
Jingyang, Teh
- Broddo2 years ago
Thanks for the reply. I can only see version 24.1 in the Pro version of Quartus. Standard and Lite are both still on 23.1. My target FPGA is a Max10 so Pro is of no use to me unfortunately. Is an update to standard and lite due?
