16 years agoError: Compiling uClinux with Frame Buffer (altfb.c)
Hi, I have a Nios II Embedded Evaluation Kit and wanted to try uClinux with frame buffer on it. (Followed the instruction on http://www.nioswiki.com/operatingsystems/uclinux/framebuffer). The S...
16 years agoThank you mmkaya,
Actually I didn't found any solution from google. I've succedded by changing the name of the VGA controller in the SOPC Builder in Quartus : VGA_0 --> vga_controller_0 So the variable na_VGA_0 which was created becomes na_vga_controller_0 and then it works fine. Best regards
