16 years agoError: Compiling uClinux with Frame Buffer (altfb.c)
Hi, I have a Nios II Embedded Evaluation Kit and wanted to try uClinux with frame buffer on it. (Followed the instruction on http://www.nioswiki.com/operatingsystems/uclinux/framebuffer). The S...
16 years agoHi mmkaya
I've just had exactly the same error while trying to make a uClinux image for DE2 board, but adding microwindows. I've followed the configs mentioned on nioswiki.com/OperatingSystems/UClinux/FrameBuffer Did you finally succeed to do so ? Hope you can help me Thank you Flo
