16 years agoError: Compiling uClinux with Frame Buffer (altfb.c)
Hi, I have a Nios II Embedded Evaluation Kit and wanted to try uClinux with frame buffer on it. (Followed the instruction on http://www.nioswiki.com/operatingsystems/uclinux/framebuffer). The S...
16 years agoThank you Hippo.
As for frame buffer, your design worked out. Unfortunatly I got an error refering to atkbd.c: altps2 : base 88001420 irq 9 mice: PS/2 mouse device common for all mice ads7846 spi1.0: touchscreen, irq 4 input: ADS784x Touchscreen as /class/input/input0 TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. Freeing unused kernel memory: 1664k freed (0x20c000 - 0x3ab000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc -o noexec,nosuid,nodev Command: mount -t sysfs sysfs /sys -o noexec,nosuid,nodev Command: mount -t devpts devpts /dev/pts -o noexec,nosuid Command: mount -t usbfs none /proc/bus/usb atkbd.c: keyboard reset failed on altps2.0 mount: mounting none on /proc/bus/usb failed: No such file or directory Command: mkdir /var/tmp Command: mkdir /var/log Command: mkdir /var/run Command: mkdir /var/lock Command: mkdir /var/empty Command: ifconfig lo 127.0.0.1 Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo Command: cat /etc/motd Welcome to ____ _ _ / __| ||_| _ _| | | | _ ____ _ _ _ _ | | | | | | || | _ \| | | |\ \/ / | |_| | |__| || | | | | |_| |/ | ___\____|_||_|_| |_|\____|\_/\_/ | | |_| For further information check: http://www.uclinux.org/ Execution Finished, Exiting Sash command shell (version 1.1.1) /> atkbd.c: keyboard reset failed on altps2.0 Due to using the keyboard won't work. Have you some advice on this one? Thanks. D.
