21 years agoError compiling sdram.v
Dear all, I recently created a new project in Verilog to test the Performance counter that seems not working in VHDL projects. Whereas the verilog fast example distributed with Nios II wor...
21 years agoYes, me!
In the same file! Altera support couldn't help. You need to open sdram.v with notepad (you will see more than in quartus,..... (!) ) this is the wrong line for my case: reg za_data /* synthesis ALTERA_ATTRIBUTE = FAST_INPUT_REGISTER=ON */; you need to manually add the " : reg za_data /* synthesis ALTERA_ATTRIBUTE = "FAST_INPUT_REGISTER=ON" */; ...after every sopc builder generation. Don't ask why... ciao Marco
