22 years agoerror compiling - linux
Hello, I changed some linux configuration and I got this error in the Nios II IDE. ***[all] Error 2 ***[lib/gen_crc32table] Error 1 ***[lib] Error 2 ... inttypes.h: No such file or...
22 years agoI think that the problem is not from the JFFS2 filesystem, but from the CRC32 library support, that is needed by the JFFS2 filesystem. I also think that the solution is to be searched into the various kernel makefile variables; may be a particular variable needs to be set to point where the uClibc resides to give the correct path to inttypes.h.
Fab
