16 years agoError Compile uCLinux for Nios II
Hello everyone, I can not fill uCLinux for nios2, I followed all the procedures of the site: http://www.nioswiki.com/, but each one gives me error. I am trying Ubuntu 9.10 x86_64 Ca...
16 years ago --- Quote Start --- I'll do my best to help but it sounds like I barely got further than you. I have two Linux systems I have been playing with this on. An Ubuntu 10.04 laptop and a Fedora Core 13 laptop. I'm like you, I wanted to try the latest and greatest version (20100628) but ran into problems. I gave up on the toolchain build. I tried 3 different tarballs with 3 different versions of GCC and it failed every time. Here's what worked for me to at least build the kernel zImage: Download and install the prebuilt toolchain. Be sure to use their exact command to untar the toolchain to preserve permissions and links and such: From http://www.nioswiki.com/operatingsystems/uclinux/binarytoolchain:
sudo tar jxf nios2gcc-20080203.tar.bz2 -C /Then I un-tarred the 20090730 version and changed into that top level directory and ran ./checkoutI then followed the directions on http://www.nioswiki.com/operatingsystems/uclinux/uclinuxdist and got a "zImage" output which I believe is the kernel image. Trying to test it now but having some SDRam issues. I can't wait until I get my hardware shaken out and can move to Linux completely. The NIOS Eclipse tools I am not liking at all. . David --- Quote End --- Now, this signal problem: [/home/thor/Scrivania/nios2-linux/linux-2.6/include/linux/jiffies.h:257:31: warning: "nasys_clock_freq" is not defined
