Error Code 8 Command: nios2-flash-programmer
- 4 years ago
Hi Jayesh
You may find the quartus_pgm command line parameters in the links below:
https://www.intel.com/content/www/us/en/docs/programmable/683118/current/quartus-pgm-nios2.html
Here are some examples for the quartus_pgm:
I shall set this thread to close pending. If you still need further assistance, you are welcome to reopen this thread within 20days or open a new thread, some one will be right with you.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if
Jingyang, Teh
Hi Jayeesh
Any update on the new tool?
I believe that the Quartus Programmer will be the tool for your use.
Jingyang, Teh
Hi Jingyang,
I will try quartus programmer as i am in another task so will try later. you can share the pdf link for using quartus programmer for programming flash.
you may close the thread as of now.
Jayesh
