Error Code 8 Command: nios2-flash-programmer
- 4 years ago
Hi Jayesh
You may find the quartus_pgm command line parameters in the links below:
https://www.intel.com/content/www/us/en/docs/programmable/683118/current/quartus-pgm-nios2.html
Here are some examples for the quartus_pgm:
I shall set this thread to close pending. If you still need further assistance, you are welcome to reopen this thread within 20days or open a new thread, some one will be right with you.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if
Jingyang, Teh
Hi Jayesh
Any update on this case?
Jingyang, Teh
- Jayeshkumar4 years ago
Hi Jingyang,
I have done as you told and following is the result of debug is attached for your reference. Please go through it.
Please let me know the alternate way to program the flash with .elf file. we need to convert .elf file to compatible flash file and load onto flash.
I was getting error code 8 when using Quartus 15.1 and now switched to Quartus 18.1 and getting error code 4 while programming the flash using nios flash programmer.
