Error Code 8 Command: nios2-flash-programmer
- 4 years ago
Hi Jayesh
You may find the quartus_pgm command line parameters in the links below:
https://www.intel.com/content/www/us/en/docs/programmable/683118/current/quartus-pgm-nios2.html
Here are some examples for the quartus_pgm:
I shall set this thread to close pending. If you still need further assistance, you are welcome to reopen this thread within 20days or open a new thread, some one will be right with you.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if
Jingyang, Teh
Hi Jayesh
For the error that you are facing could you send me a screen shoot of the whole error reported text and the nios2-flash-programmer command?
Furthermore could you also descript the environment you are working on? (eg. what board/ device you are using? )
At the meantime could you check the if there are any warnings/conflicts on the NIOS2 PLL settings for the SDRAM clock and the CPU clock?
It is recommended to have 3 separate clock source for the CPU, internal SDRAM module, and external SDRAM module.
Jingyang,Teh
- Jayeshkumar4 years ago
Hello Jingyang,
Following is the whole error:
Info: 30 May, 2022 11:33:05 AM - (INFO) elf2flash: args = --input=C:/jayesh/AKASH_ARMY/mtx_firefly_4c40/software/hello/hello.elf --output=C:/jayesh/AKASH_ARMY/mtx_firefly_4c40/flash/hello_flash.flash --boot=C:/altera/15.1/nios2eds/components/altera_nios2/boot_loader_cfi.srec --base=0xa000000 --end=0xc000000 --reset=0x0 --verbose
Info: 30 May, 2022 11:33:05 AM - (FINE) elf2flash: Starting
Info: 30 May, 2022 11:33:05 AM - (WARNING) elf2flash: Supplied reset address: 0x0 differs from the elf file reset vector: 0xa000000.
Info: 30 May, 2022 11:33:05 AM - (FINE) elf2flash: Done
Info: Using cable "USB-Blaster [USB-1]", device 1, instance 0x00
Info: Resetting and pausing target processor: OK
Info: No CFI table found at address 0x0A000000
Info: Original contents (after writing 0xF0 and 0xFF00FF to address 0x0A000000):
Info: 0: 98 00 00 01 3A 20 00 00 01 3A 88 01 00 01 37 42 ....: ...:....7B
Info: 10: 80 08 01 3A 88 B3 C8 01 2C F0 81 C8 01 1E F8 3F ...:....,......?
Info: 20: 10 01 35 D6 40 08 01 37 00 80 F0 01 35 BD 80 08 [email protected]...
Info: 30: 01 C4 FF BF 00 01 35 F0 80 08 01 BA 30 05 00 01 ......5.....0...
Info: 40: 7A 30 07 00 01 FA 30 09 00 01 3A 31 0B 00 01 35 z0....0...:1...5
Info: Contents after writing 0x980098 to address 0x0A0000AA:
Info: Same after writing 0x980098 to address 0x0A000154:
Info: Same after writing 0x00980098 to address 0x0A0002A8:
Info: Same after writing 0x980098 to address 0x0A000055:
Info: Same after writing 0x980098 to address 0x0A0000AA:
Info: Same after writing 0x00980098 to address 0x0A000154:
Info: Same after writing 0x980098 to address 0x0A0002A8:
Info: Same after writing 0x00980098 to address 0x0A000550:
Info: Ignored possible autoselect code 04-04 as no override data
Info: present in section [FLASH-04-04]
Info: Ignored possible autoselect code 0004-0004 as no override data
Info: present in section [FLASH-0004-0004]
Info: Ignored possible autoselect code 00000004-00000004 as no override data
Info: present in section [FLASH-00000004-00000004]
Info: Leaving target processor paused
Error: Error code: 8 for command: nios2-flash-programmer "C:/jayesh/AKASH_ARMY/mtx_firefly_4c40/flash/hello_flash.flash" --base=0xa000000 --accept-bad-sysid --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-1]' --program --verbose --erase-allWe are using Device : Cyclone IV : EP4CE55F23I7
The compile log report is attached herewith for your reference
We are using external PLL IP where the source clk is 24MHz and it is constraint in sdc file. There are two output clocks both are 100MHz out of which one is used for external SDRAM (External to FPGA) and other is used for NIOS. There is no internal SDRAM used in our project.
