21 years agoError Building Linux Kernel Project
I'm using a Stratus II development board, and have a new installation of Linux using Setup. Referring to the Nios II Linux Quickstart Guide, I'm stuck on Building the kernel and receive...
21 years agoIt looks like the cygwin extensions didn't install properly on your system... I say this because it can't find gcc, and it thinks you're trying to build an i386 architecture.
Can you send me the following info? (1) the contents of: c:\Program Files\Microtronix Nios II Linux Distribution\install_settings.cache (2) The value of the following SYSTEM environment variable: $QUARTUS_ROOTDIR (3) Where your altera nios2 kit was installed (typically c:\altera\kits\nios2) (4) Where you installed Quartus II v5.0 For point (2), start up a Nios II SDK shell and type: echo $QUARTUS_ROOTDIR to retrieve the value I'm looking for. I should be able to get you up and running with the above info...
