17 years ago
Error Building Binary Toolchian
I'm trying to build the binary toolchain. After building the binary toolchain I try to put the path to locate the tools, I follow the steps of NiosWiki and when I verify, it doesn't go.
I'm using ubuntu 9.04 and I introduce the path in /.bashrc for example :
PATH=$PATH:/home/Escritorio/Fpga/nios2-linux/toolchain-build/build/nios2/bin
If someone can give an idea, sorry for my ignorance I'm a noob.
Thanks a lot
    put
    --- Quote Start ---
    --- Quote End ---
    in ~/.profile
    "~/" refers to your home directory. Same path for .bashrc
    Thanks for the answer.
    I have made what you say and it doesn't go yet. Aulthought I have continuo with the prebuilt binary toolchain, inserting the path the same as before and this time the terminal recogmize de command of nios' compiler.
    Thanks for your help
