Benitez__Domingo
2 years agoError: BSP component drivers cannot specify mutually independent interrupt APIs
Hi, I am trying to migrate a golden system reference design (GSRD) for the Terasic DE0-Nano board that is based on a Nios II/e processor to another GSRD for the same board but based on a Nios V/m pr...
AnnC_Altera
2 years agoHi,
The component is “Parallel Port” under University Program and I wonder it is not in good status to support NiosV right now.
I would suggest you to replace them with the "PIO (Parallel I/O) Intel FPGA IP" and try it again to see if the error can be removed.
Ann
- Benitez__Domingo2 years ago
The error was removed by replacing the “Parallel Port” under the University Program with the "PIO (Parallel I/O) Intel FPGA IP".
Thank you very much.
It would be nice if the "SDRAM controller IP" were available because the 32 MB of RAM memory available in the DE0-Nano board cannot be used. Anyway, some help to guide me in implementing such a memory controller is welcome.Best regards,
Domingo
