15 years agoerror before download in NIOSII
I try to make a first draft with the processor NIOSII. I get an error that I do not understand when I start my program. "Expected base address of system ID component is undefined" It see...
15 years agoBonjour
I have had that problem, This is what I do : 1) load your image (*.sof) with The programmer I start the programmer from Quartus , but it should not matter where you start it from. 2) Run Configuration => NIOS II hardware , go to the Target connection Tab and do Refresh until the connection appear. Do refresh anyway. Then RUN. I also had problem running modelsim from ECLIPSE (run CFG => Modelsim). It would not start my Modelsim because of some PERL errors. I did upgrade to 10.1sp1 and the problem is now gone. Hope it helps Benoit
