21 years agoerror at ide-flashprogrammer
can someone confirm this:
i have a custom board with a cyclone device at the jtag-chain at position 2, and have just updated from niosII 1.01 to version 1.1. Now if i open the flash programmer dialoge and select "target-connection", I can select the dowload cable and the jtag device. So far so good - if i select both to automatic, the command line flash programmer issues "Error opening target hardware" - he can't find the cyclone device. If, on the other hand the propper download cable and the right device is selected, the same error occours - because the device number is missing at the command line call !! if i add the --device=2 (as set in the dialoge) at the xxx_programmer.sh file, it works without any problem... Is it just my installation or is there an error at the nios IDE? thanks stonieNo RepliesBe the first to reply
