16 years agoError after switching to NIOS 9 sp2
Hi, I was using NIOS Version 8.1 for a while. Now we are trying version 9 sp2 on the same machine. We have succesfully created new sof and ptf file. And successfully compile the code in NI...
16 years agoI tried to change:
--instance=1 to --instance=0 And press the "Run" button, it is now giving the following error. I will ask for jdi as well. --- Quote Start --- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x06421558: ID value does not match: read 0xFFFFFFFF; expected 0x3DE92947 Timestamp value does not match: image on board is older than expected Read timestamp 11:59:59 1970/01/01; expected 14:21:45 2009/11/10 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor --- Quote End --- Thanks.
