16 years agoError: 2 when I build toolchain uCLinux on ubuntu 9.04 _x64
Hi! I have problem with building toolchain uCLinux on Ubuntu 9.04 _x64. I did everything what is descibed here -> http://www.nioswiki.com/installnios2linux and I used gcc in version: 3.2, 4.1, 4....
16 years agoCould you post the errors?
I never did quite get the toolchain build working on 64-bit, but one thing I had to change on Ubuntu is to add -D_FORTIFY_SOURCE=0 to gcc's CPPFLAGS. Also, if you are interested in using an MMU (virtual memory) with real libc/Linux instead of uClibc, the instructions are here, and you don't need to build that toolchain: http://nioswiki.com/linux
