A_Torres's avatar
A_Torres
2 years ago
Error 13223 when using NIOSV/m on Quartus 23.2 Pro
I'm trying to compile a simple project with NIOSV and an on-chip memory.
I'm using Quartus Prime Pro 23.2 and Cyclone 10 GX.
I activated the free NIOSV/m license in Altera Self-Licensing Center and I'm using it as a floating license. I can see the license in Quartus License setup: "Nios V Soft Processor FPGA IP - M Core (D036)".
But when I'm trying to compile the project I get this error for 20 NIOSV files:
Error(13223): Verilog HDL or VHDL error: cannot open Verilog file '<filename>.sv'
Any solution for this problem?
Attached the free license I activated and the license I see on Quartus License Setup.
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Can you help to provide the NUC ID for the machine that you use and also your .dat file?
    Aqid
    • A_Torres's avatar
      A_Torres
      The NIC ID is: 0015F257D997
      I have other floating licenses running in the same machine so I attached the NIOS V license to that file.
      The NIOSV license is attached here as a .txt since I cannot upload .dat files.
    AqidAyman_Altera
    Server setup issues: Common in floating license environments where the server cannot allocate licenses to your machines.
    Example: Multiple users in an organization cannot checkout licenses because the license server is down or misconfigured.
    Can you help to check the server's status and ensure the port is open?
    You can also refer to the link below for more detailed instructions for Setting up a floating network license server (starting from page 84):
    https://cdrdv2.intel.com/v1/dl/getContent/821877?fileName=quartus_install-683472-821877.pdf
    Aqid
    AqidAyman_Altera
    I noticed the same issue has been escalated to Intel Premier Support. I will close this one and please continue the communication through the IPS.
    regards,
    Aqid
