19 years agoerror : memory exhausted
When I try to run my application I get "memory exhausted" message. I have passed "mem = 32M" as kernel parameter to increase the ram allocation to kernel to 32 MB. But it still doesn't work.
You don't need to give "mem=xxx" to kernel. The nios2 arch setup.c will use all sdram.
Please check available memory before your application, with "free" or "cat /proc/meminfo". You should also check memory required by your application. The error may also come from corrupted memory. - Altera_Forum
Hippo,
My application uses non padded buffers of total size 2 MB. I have 32 MB RAM on baord and when i use free i see about 25 MB if free. My application works fine when i use non padded buffers but when i try to run the same with padded buffers it gives me "Memory Exhausted" error. When i say buffer i am referring to structures. What could be the problem? - Altera_Forum
I don't understand your problem about padding.
One important difference between RISC and x86 is that RISC can not access unaligned word. eg, read 32 bits word from address 4 is OK, but read 32 bits word from address 5,6,7 is wrong. so you may need to 4 read bytes from address 9, and shifted to make a 32 bit word. This applies when you read or write a unaligned member in a structure. - Altera_Forum
Hello hippo ,
I've read this post. And even when it is a little old, I have the same problem. You mentioned something about corrupted memory. Is there a way to read from the memory or verify that it is not corrupted? I'm getting the same memory exhausted message. Regards, Francisco
