21 years agoerr opening dev/dsp
Hi folks
I am having a problem opening /dev/dsp with an application. It tries to open the device /dev/dsp # define AUDIO_DEVICE /dev/dspfd=open(AUDIO_DEVICE, O_RDWR|O_NONBLOCK); this returns -1 to fd. I tought this might be because I'm using a ROM filesystem. Therefore I tried using fd=open(AUDIO_DEVICE, O_RDONLY|O_NONBLOCK); this did'nt help though. Any ideas what to do? Regards Michael E1 Reply
Did you add the correct functionality in the kernel?
Using a RO filesystem should not be a problem since /dev/ entries are not a real file but a fake filesystem to access kernel functionality. I would assume this error results from static device nodes (i.e. always there) without having the correct functionality in the kernel (device module/driver). You try to access the kernel, but the kernel does not know what you are talking about.
