21 years agoEPCS with nios2-flash-programmer
Hi, I use Quartus 4.1 SP2, NIOSII SP1 my system consists of : EP1C6, CFI FLASH , EPCS1 or: EP1C6, CFI FLASH , Configuration EPLD) (either the Confi...
21 years ago --- Quote Start --- originally posted by fischer@Nov 3 2004, 08:24 PM it seems that the programmer works ok, but nios program does not start, also
the debugger does not start.
both signals nstatus and conf_done go high after power up.
why does the above first converting program uses "--device=epcs4" ? --- Quote End --- Did you try selecting the EPCS1 in your Quartus project under Files --> Convert programming files?
