20 years agoEPCS under uCOS/II
I'm trying to programme an EPCS over TCP/IP and NIOS running uCOS/II. Problem is, the only way to access the EPCS is via HAL API, which says "single threaded only". Small operations, like a singl...
20 years agoHi AlanBall,
I simply used the functions OSTaskSuspend(),OSTaskResume().I think the functions you are using, have the same effect.So have you check your task stack size?Only an idea... bye
