21 years agoEPCS Under Q4.2
Is the documentation correct for the EPCS device controller? Under Q4.1 the size of the boot loader rom was specified as 256 Words or 1Kbytes, The control registers are located immediately af...
21 years agoHi everyone,
I have nearly the same problems that cybdenw posted. But my design is not using the boot_loader_epcs_bit.s. It uses the boot_loader_cfi.s instead (the reset-address points to flash at 0x0). The software works fine when downloaded directly. But when I use the flash in combination with the bootloader it seems that the program-counter is not set up to the right ram-address after the program-code is transfered to sdram. After system-reset nothing is excecuted, but when I reset the cpu manually after system-reset, the program executes as expected. So, could it be that there is the same error in the cfi-boot-loader, too?
