19 years agoEPCS selection in Nios-IDE
Hi Folks, In the original version of a project, my system was based around the EPCS64, as I planned to have both the FPGA image and the Nios-II Application stored in the one device. I have...
19 years agoDear Sir,
I am New to this Cyclone 2 FPGA testing. We have develoed our hardware board with Cyclone II FPGA> we have EPCS4 for Serial Flash Purpose. Can u guide me how can i test that EPCS4 controller. How can i load my Hardware Image and Elf files to that Controller. I want to run my total application in that EPCS4 Controller. Thanking u Regds ATLURI --- Quote Start --- originally posted by devans@Nov 10 2006, 11:46 AM hi folks,
in the original version of a project, my system was based around the epcs64, as i planned to have both the fpga image and the nios-ii application stored in the one device.
i have now moved the application to be stored in external flash, and want to move to an epcs4.
i have changed all the settings in quartus to target .pof output for an epcs4, and re-complied the design. i have even built up a simple hello world test project from scratch.
however, every time i run the flash programmer with the epcs4 board attached, flash programmer fails. lookng back through the various commands that have been run, there is a command line with a --epcs64 reference.
if i connect up my old board with the epcs64 fitted, all is well.
how do i set the nios-ide so that it knows to target an epcs4?
regards,
david
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19367)
--- quote end ---
--- Quote End ---
