20 years ago
EPCS Programmer error
hi, I have an only EPCS4 on my cyclone board (1c12) and I want to program EPCS4 but i fail.
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
#! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd E:/gxh/flashOnePIO/flashOnePIO/software/hello/Debug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --epcs --input=E:/gxh/flashOnePIO/flashOnePIO/xby.
sof --output=xby.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=xby.op
t E:/gxh/flashOnePIO/flashOnePIO/xby.sof xby.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Processing ended: Fri Sep 15 12:05:44 2006
Info: Elapsed time: 00:00:03
Info: Command: quartus_cpf --no_banner --convert xby.pof xby.rpd
Info: Processing ended: Fri Sep 15 12:05:46 2006
Info: Elapsed time: 00:00:01
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --sidp=0x01201038 --id=1622478268 --t
imestamp=1158289160 --epcs --base=0x01000000 xby.flash
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x01201038: verified
No EPCS layout data - looking for section [EPCS-FF]
Unable to use EPCS device
Leaving target processor paused
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --epcs --after=xby.flash --input=hello.elf --outpu
t=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_load
er_epcs.srec
# Programming flash with the project
imestamp=1158289160 --epcs --base=0x01000000 epcs_controller.flash
Leaving target processor paused[/b]
--- Quote End ---
What could I do ?
please help me. Thank you.
    Hi Snowfox!
    I&#39;ve got the same problem with ep1c6 and epcs4.
    Although, I had no problem at all with ep1c12 with epcs4.
    Everything is under nios 5.1
    Have you solved the problem?
    I had the same problem when I received my target board and it turned out to be a cold solder on the EPCS device on my board. So I would assume your EPCS device is either not working or not connected properly to you FPGA.
