16 years agoEPCS NVRAM help
Does anyone know how to setup u-boot so that the CFG_ENV_ is stored in EPCS and does anyone know how to bootm from EPCS
I have managed to store an image in the EPCS My CFG_NIOS_EPCSBASE is 0x08001000 and this is the only NVRAM I have available2 Replies
The EPCS has boot_loader itsself, so you only need to store your program and hardware configuration into the EPCS through the NIOS2 IDE tools <program Flash. the both program will be load from EPCS automatically when power-up reset.
However, you must add a EPCS controller to your system in SOPC Builder! - Altera_Forum
Thanks for the reply.
I am trying to use u-boot and I already have EPCS controller added to my system and when it starts the FPGA configuration and u-boot is loaded but I have no EEPROM on my system so:- I would like to know how to store/recall u-boot environment variables from EPCS and also how to use the bootm command from a locations in EPCS Many thanks
