20 years agoEPCS FLASH Programming
Is there any way to Flash program an EPCS that is connected for Active Serial Programming to a CYCLONE device without using the JTAG pins on the Cyclone device ? Is there a way to program the EPCS di...
20 years agoYes, shmueld. Check the configuration devices handbook. Connect the USB-blaster to your EPCS through a AS-config port. I did that in the past and it works well. I would not recommend though, because severely limits your debug capabilities. You can use a JIC file to directly program the EPCS through JTAG by using the Quartus programmer without using the nios flash programmer utility.
Arjan
