16 years ago
EPCS Flash Programmer
I am using Stratrix II EP2S180F1020. UFM device used here is EPM240GT100. I am running a simple Hello World Program.
When I select the device and try to Program it Through Flash Programmer I get these message.
Executing command: bin2flash --input="C:/aAJIT/quartus/ravi-flash1-new/software/ravi_flash5/hello_world.c" --output="C:/aAJIT/quartus/ravi-flash1-new/software/ravi_flash5_bsp/flash/hello_world_e.flashs.flashontroller.flash" --location=0x0 --verbose
Sep 25, 2010 2:33:33 PM - (FINE) bin2flash: Starting
Sep 25, 2010 2:33:33 PM - (INFO) bin2flash: args = --input=C:/aAJIT/quartus/ravi-flash1-new/software/ravi_flash5/hello_world.c --output=C:/aAJIT/quartus/ravi-flash1-new/software/ravi_flash5_bsp/flash/hello_world_e.flashs.flashontroller.flash --location=0x0 --verbose
Sep 25, 2010 2:33:33 PM - (FINE) bin2flash: Done
Executing command: nios2-flash-programmer "C:/aAJIT/quartus/ravi-flash1-new/software/ravi_flash5_bsp/flash/hello_world_e.flashs.flashontroller.flash" --base=0x4009800 --epcs --sidp=0x400A078 --id=0x7A06A701 --accept-bad-sysid --device=2 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program --verbose
Using cable "USB-Blaster [USB-0]", device 2, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x0400A078:
ID value verified
Timestamp value was not verified: value was not specified
Processor data bus width is 32 bits
Looking for EPCS registers at address 0x04009800 (with 32bit alignment)
Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A
Not here: reserved fields are non-zero
Looking for EPCS registers at address 0x04009900 (with 32bit alignment)
Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C
Looking for EPCS registers at address 0x04009C00 (with 32bit alignment)
Initial values: 00000000 00000000 00000260 00000000 00000000 00000001
Valid registers found
EPCS signature is 0xFF
EPCS device doesn't support RDID command
No EPCS layout data - looking for section [EPCS-FF]
Unable to use EPCS device
Leaving target processor paused
I am not getting where is the error. Thank u in advance for your help
    The flash programmer (AFAIK) is only intended for EPCS devices. You'll have to figure out another way to program the UFM on your MaxII device. Have a look at AN489 for reference.
    --slacker
    emmanuelajit
    Have you find the solution of your problem? Because i have the same problem and i cannot solve it?
    Thank you,Slava.
