16 years agoEPCS flash access on BeMicro
Hi, I am doing some debugging using the BeMicro Cyclone III dev board. I have installed a serial configuration device on the board and I want to test the SOPC EPCS Flash controller. I am not u...
16 years agoThe jumper (B400) on the Bemicro must be changed or the EPCS cannot work. An unchanged B400 places the FPGA in Passive Serial Mode. After configuration the DCLK pin (H1) will always be an input. It needs to be an output for EPCS usage. Other pins may also be a problem, but this one is definitely a problem.
