20 years agoEPCS embedded reprogramming
Hi, I'm trying to figure out how to reprogram the epcs from within the uClinux environment on the NIOS. Has anyone tried this. Is it possible to use the MTD drivers for the EPCS to reprogram...
20 years ago --- Quote Start --- originally posted by hammer42@May 25 2006, 10:42 PM hi,
i'm trying to figure out how to reprogram the epcs from within the uclinux environment on the nios. has anyone tried this. is it possible to use the mtd drivers for the epcs to reprogram the entire epcs including the fpga code? any help would be much appreciated.
thank you,
brian hammerbacher
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15573)
--- quote end ---
--- Quote End --- Look at the flashw util in uClinux-dist .
