20 years agoEPCS embedded reprogramming
Hi, I'm trying to figure out how to reprogram the epcs from within the uClinux environment on the NIOS. Has anyone tried this. Is it possible to use the MTD drivers for the EPCS to reprogram...
20 years agoHi Brian,
> Has anyone tried this. Yes. jdhar has developed an MTD driver. The code is part of the buildroot sources. You can also program the epcs device using u-boot. > Is it possible to use the MTD drivers for the EPCS to reprogram the entire EPCS including the > FPGA code? Any help would be much appreciated. Yes, provided you can create a valid binary file. Regards, --Scott
