20 years agoEPCS Driver and Document
Greetings all, I have added links below for a couple things; first, a diff patch to the uclinux 2.6.11 kernel that allows you to use the EPCS configuration device for filesystems. Second, if y...
20 years agoHello...
Just wanted to raise the awareness of the "virtual memory" EPCS peripheral (http://www.fpga.nl/index.html?ipcores.html). It doesn't look like it's been updated in a while, but it should provide a cleaner interface to everyone interested in using an EPCS and/or serial (SPI) flash device. This is also mentioned on the "Post Your IP" section of this forum. In fact, I think it was one of the first to be posted... Best Regards, - slacker
