20 years agoEPCS Driver and Document
Greetings all, I have added links below for a couple things; first, a diff patch to the uclinux 2.6.11 kernel that allows you to use the EPCS configuration device for filesystems. Second, if y...
20 years agoHi, J,
Please check post#52 in the buildroot guide. There is the pci driver in kernel 2.6.15.6 . For SD/MMC based on spi, I think it would be better to use MMC instead of MTD. The MMC driver has the higher level block devices drivers.
