20 years agoEPCS Driver and Document
Greetings all, I have added links below for a couple things; first, a diff patch to the uclinux 2.6.11 kernel that allows you to use the EPCS configuration device for filesystems. Second, if y...
20 years agoI will look into using the new kernel. Unless they changed the MTD layer, the EPCS Driver shouldn't be broken since it's relatively simple. I will work on getting .15 up in my environment, and then eventually move to .16.
If you got a working PCI Driver, that would be great. I have a few custom boards with miniPCI Bus on them, so I could easily test them out. One thing that is currently missing from my driver is write-verification. When it writes, it doesn't read back to check if it's correct. Is write-verification typically done in low-level drivers? It would make sense ,but given the low-speed of SPI Flash devices, I'm not sure whether I should implement it or not. Also, if you are going to include the EPCS MTD driver in the next kernel build, how should I keep it updated? Do I just send you patches? I was thinking of implementing an SD/MMC MTD Driver in SPI Mode since it wouldn't be too difficult either. Let me know your thoughts on this.... or if I should try to go through the MMC Driver section instead.
