20 years agoEPCS controller booting trouble
Dear NIOS friends, I am porting a system that was developed on a (custom board) with a EP1C6 to a new board revision with a EP2C8. Both are configured with an EPCS4 device and it worked very we...
20 years agoHi Arjan,
Assuming you're doing everything the same WRT to programming the epcs device and using on-chip v. sdram, I would still be suspicious of the sdram controller/device itself. Is there any chance your memory tests are missing failures. E.g. -- are you using a data cache, but forgetting to flush/invalidate before doing the read back? > Is the bootloader that comes with the NIOS kit smart enough to know where to > copy the NIOS code? Yes -- basically for each elf (output) section there's an address-length-data record that gets programmed into the epcs. The address/length is the VMA/size from the corresponding section in your elf file. It would be a good idea to check your elf file (via objdump) to make sure your sections are where they need to be and review jdhar's document. Regards, --Scott
