20 years agoEPCS boot understanding
Hi guys, I have a 2C8 board with a EPCS4 flash for FPGA configuration and software. Now I trying to get both in the flash: SOF conversion: sof2flash --epcs -input=nem2.sof --output=nem2....
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- The syntax has changed a bit ... but hopefully that won't slow you down too much ;-)[/b] --- Quote End --- Not really http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif I have another question. Is it possible to put the programcode at a definded address at the epcs device? I mean using a command like --address=0x40000 instead of --after=xyz.flash for the elf2flash tool. kind regards
