20 years agoEPCS boot understanding
Hi guys, I have a 2C8 board with a EPCS4 flash for FPGA configuration and software. Now I trying to get both in the flash: SOF conversion: sof2flash --epcs -input=nem2.sof --output=nem2....
20 years ago> @smcnutt: The commands u used are not supported with the 5.1 flash-programmer.
Really? The "Nios II Flash Programmer User Guide" (October 2005 -- which includes updates for Nios II Version 5.1) has the command listed in Section 3, "Using the Flash Programmer in Command-Line Mode". The syntax has changed a bit ... but hopefully that won't slow you down too much ;-) --Scott
