11 years agoEPCS access fail
Hi there
I'm having trouble accessing the EPCS from withing NIOS. When running the following code: void OpenEpcsFlash() { fd_f = alt_flash_open_dev(EPCS_FLASH_CONTROLLER_NAME); alt_printf("EPCS pointer: %x\r\n",fd_f); } fd_f always returns a NULL pointer. I've enabled small_device_drivers and the small_c_library, but I've included the ALT_USE_EPCS_FLASH# define. If I run the exact same code on the DE0_Nano_SOPC demo project, included in the Altera DE0 Nano board, the software works. Is it possibly a setup problem in my Qsys system? I'm using Quartus 13.1.0. Thanks in advance Jean2 Replies
I found the problem. The# define ALT_USE_EPCS_FLASH, is removed each time the BSP is regenerated. Thus it needs to be added after BSP generation.
Hope this helps someone in the future Kind regards Jean - Altera_Forum
There are others cases where some user installed the EDS and tool chain in different folder location where causing the inclusion path is not updated correctly. :)
