21 years agoEPCS : update FPGA config data and NIOS software
Hi, I currently use NIOS II v5.0 and I want to update the FPGA configuration Data and the NIOS sofware ( which are twice stored in the EPCS memory) with an Ethernet network. Anybody h...
21 years agoHi Etienne,
> I want to update the FPGA configuration Data and the NIOS sofware > (which are twice stored in the EPCS memory) with an Ethernet network. You can use u-boot to this via tftp and its epcs read/write/verify commands. You will need to convert your flash files to binary though. > Anybody has a little piece of code to do that ? That depends on what you mean by 'little' ;-) Regards, --Scott
