20 years agoEPCS : read electronic signature
I need to identify the EPCS that is linked to my fpga. How can I get the electronic signture of the EPCS ? I have called the alt_epcs_flash_init(handle_epcs) function but my software is faulty after the call of this function. What can I do to get it ? I thank you, Etienne5 Replies
Etienne,
Have you tried single-stepping through this code to find out what is failing? In any case, the command that determines the flash's "silicon ID" is contained within the very function you're referring to:
Best of luck! - slacker/* Send the RES command sequence */ flash->silicon_id = epcs_read_electronic_signature(flash->register_base); - Altera_Forum
I thank you for your answer, but It doesn't work in my project. When I call the function, the software never goes out ? Do you have an idea ?
I thank you again --- Quote Start --- originally posted by slacker@Nov 12 2005, 06:52 PM etienne,have you tried single-stepping through this code to find out what is failing?
in any case, the command that determines the flash's "silicon id" is contained within the very function you're referring to:
/* send the res command sequence */ flash->silicon_id = epcs_read_electronic_signature(flash->register_base);best of luck!
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=10952)</div> --- Quote End ---
Etienne,
I'm sorry, but I don't know what you mean by "the software never goes out". Do you mean that this software is never called from within the alt_sys_init() function? Do you mean that the software fails to find a silicon_id? Or something else? Please elaborate. - slacker - Altera_Forum
We've struggled with a similar problem and so I'd be interested in knowing what you've found.
I've put breakpoints in alt_epcs_flash_query where it does the call: flash->silicon_id = epcs_read_electronic_signature(flash->register_base); and have seen rather intermittent results, i.e. sometimes it reads the signature okay and sometimes it doesn't. It often changes its behavior when I re-download the .sof file. We are running on our own hardware with a 2C20-C8. We are using a STM serial flash M25P64V6G. We have Quartus 5.1 and Nios 5.1. We've looked at the read sequence on a scope and when it fails it looks .... funny, it gets 0 back for the signature and other random stuff. The read signature sequence should be 40 clocks. They are being done a byte at a time which makes sense as they are coming out of a SPI controller but there is a long time between bytes, about 10 us, the clock is 12.5 MHz. Has anyone experienced similar problems? Mike - Altera_Forum
Did you specify a reference designator in your SOPC configuration? You need to run mk_target_board as detailed here...
http://www.altera.com.cn/literature/ug/ug_..._programmer.pdf (http://www.altera.com.cn/literature/ug/ug_nios2_flash_programmer.pdf)
