14 years agoendless loop in stock interrupt handler
Hi people, a bit of information about my system first: - terasIC DE2-115 evaluation board with Cyclone IVE FPGA - Nios II/s CPU - also part of CPU block: SDRAM Controller, PIO, SysID, 2x ...
13 years agoI don't know freeRTOS, but you must be very careful in using interrupt control functions with an underlying OS.
Infact, an OS relies on a high priority irq to schedule application tasks; application usually doesn't work with irq at the raw level, but the OS emulates the required hw behaviour through sort virtual IRQs and the scheduling process. For example, if you use sys timer irq or any other device required by OS, you may corrupt the OS itself and your system would stop working. What I mean is that under an OS, using raw IRQs is possible but is not recommended unless you have a comprehensive knowledge of your OS's ineer workings and you are aware of what you are doing.
