21 years agoEncrypted VHDL file
Hi, I recently received Nios-II update package. When trying to open a VHDL source in cpu.vhd, I got the following message. "Can't open encrypted file "C:\altera\kits\nios2\examples\...
21 years agoHummm, you want to add a branch predictor. You could always just modify the perl code used
to generate the RTL. Look in c:\altera\kits\nios2\components\altera_nios2\*.pm. Note that all the comments are stripped out (replaced with empty lines).
