20 years agoEnable C2H mode
Hi All,
I want to use C2H compiler and i have a evaluation of that but when i want any function to be C2H function then NIOS IDE give me the instruction like this "To use C2H compiler you must enable evaluation mode".So what is it? i checked the plugins of my NIOS IDE and it already include C2H plugins. So from where i have to enable the evaluation mode? Reply me ASAP.. Best Regards, slsnios4 Replies
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
It need to OCP File ( look like NiOS2 \components\altera_avalon_c_hardware_accelerator\hdl\c2h_port_byte_refine.ocp ) I guass that C2H is not release...just C2H is promotion.... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif --- Quote Start --- originally posted by slsnios@Jun 13 2006, 11:48 PM hi all,i want to use c2h compiler and i have a evaluation of that but when i want any function to be c2h function then nios ide give me the instruction like this
"to use c2h compiler you must enable evaluation mode".so what is it?
i checked the plugins of my nios ide and it already include c2h plugins.
so from where i have to enable the evaluation mode?
reply me asap..
best regards,
slsnios
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16163)
--- quote end ---
--- Quote End ---
Check out this page first:
http://www.altera.com/products/ip/processo...2h/ni2-c2h.html (http://www.altera.com/products/ip/processors/nios2/tools/c2h/ni2-c2h.html) In short you have to contact your sales rep, refer to this page if you do not know who your rep is: http://www.altera.com/corporate/contact/con-index.html (http://www.altera.com/corporate/contact/con-index.html) - Altera_Forum
Thanx BadOmen
I did all the stuffs and also read all the documents which u provided but still i am not getting any help about that. I also contect to my sales rep but he is also not knowing the thing. Are u using C2H compiler or not?? I already post my thread on altera online help but still i am not getting the help from them. If you have any idea to this then reply me back Best Regards, slsnios - Altera_Forum
I'd probably ask your sales rep if they can forward your request to someone else in the sales channel that may be able to help you out.
