Broddo
6 years agoenable_alt_load_copy_rodata disabled in BSP Editor when using uC/OS-II
I'm using Quartus II standard 20.1. I have a simple system designed using Platform designer that incorporates standard stuff (Nios II, PLL, RAM, on-chip flash etc). I intend to execute code fro...
Eliath_G_Intel
6 years agoHi Barry,
I've been trying to reproduce your issue but I haven't had any success.
in the tests I made, the alt_load functions never got disable.
Would you mind to share your *.sopcinfo file with me to see exactly the way you have configured it and then reproduce the issue?
Thanks in advance,
-Eliath Guzman
- Broddo6 years ago
Apologies for the delay - here is my sopcinfo file if it is any use to you. I changed the file's extension to .xml as the forum forbids uploading of files with extension .sopcinfo.
