21 years agoEmbedded webserver w/Scripting
Hi - I'm looking at implementing a simple webserver with some ultra-simple server-side scripting/macro-expansion. The webserver 'example' that's programmed into the NIOS evaluation bo...
21 years agoI'll post the modified http server source tomorrow... look for it in the 'post your ip' section. We just implemented a simple token-parsing method that replaces strings (of a known length, that matches, say, an ip address), with the actual address in use by the system. It isn't very powerful given that limitation... but it does allow the server to parse things on the fly as its sending packets down the wire.
