16 years agoelf2flash issues
All, . I'm having some issues with the elf2flash utility and I'm hoping you can help me. . When I run the elf2flash utility on a particular .elf application file, it does not put the lengt...
16 years agoIf you just want the contents of an elf section, it is probably simpler to use:objcopy -O binary -j <section_name> <input_file> <output_file>
Add '--set-section-flags <section_name>=contents,load' to extract a non-loadable section (eg .comment)
