16 years agoelf2flash issues
All, . I'm having some issues with the elf2flash utility and I'm hoping you can help me. . When I run the elf2flash utility on a particular .elf application file, it does not put the lengt...
16 years agoOkay I found the issue. The problem is that I'm creating a boot record for a nios processor that is not connected to the flash where I'm storing the application image. And in this particular case, the address of the processor overlaps the address of the flash. So there was no need for the length and addres records. I just lied to the utility about the flash begin and end addresses. I convert it to binary at the end anyway.
Jake
