13 years agoelf2flash for Stratix-IV PCB instructions confusing...
I have a NIOS II design for the Stratix-IV 530KHC2 Dev. PCB. Hardware works, software works fine when downloaded via Eclipse. The HW is now programmed into FLASH fine. Now I want to program the S...
13 years agoEven though I got a warning about the conflict between then BSP reset address of 0x00000000 and the command line of --reset=0xB4A0000 it did produce a .FLASH file. I used this .FLASH file with
"nios2-flash-programmer --base=0x08000000 my_prog_4_24_sw.flash" and it programmed the FLASH fine, however when booting it the NIOS Console did not display my prompt. So I tried a simple program that displays on the LEDs a software generated count and it works ! In other words the SW which was burned into FLASH booted and ran fine. I still don't know why it does not access the NIOS Console. Shvitzer
